Had been having trouble on occasion with F1 error code showing upon touchpad on occasion, would follow directions to clear it. Then went to self-clean oven, after cycle, oven door won't unlock, F1 error code is displayed. Can't use touchpad, whatever I try, keeps going back to F1 Can't unlock oven door
JBrant
if clock or "erc' is intergrated with touch pad replace clock.ifconnected by membrane conduct test by shutting off power to range ,acess erc or clock disconnect membrane from clock .turn power back on .wait at least an hour if f1 comes back ,it may also beep replace clock ,if f1 does not come back replace touch pad
