Please help appliane pros The light bulb burned. Wondering if its a regular halogen I can buy at the hardware.
Also, any one can give me step by step instructions
I heard the whole unit needs to be taken out with the white borders removed first. I cannot locate the plug and I suppose it is behind the unit and I will see it when I remove it.
Hi Johny, You were right. The microwave has to be removed from the oven body. The instructions are attached to the reply. - The halogen lamp Part number: AP3846617
