Recently purchased replacement T-stat from you folks Part #4344659. Need wiring diagram so I don't attach wires incorrectly.
THIS FORUM IS DEAD!!!!!!! |
Replacement T-stat has one trminal marked "3" and one terminal marked "4". Which one gets black wire?
Existing T-stat has one terminal marked in (black connected) and one marked out ( blue connected).
Thanks.
Hi Steve, As you can see from the part pictures    and the wiring diagram the thermostat has only two terminals. There is no difference which wire where goes. Gene.
Originally Posted by: Gene  Hi Steve, As you can see from the part pictures    and the wiring diagram the thermostat has only two terminals. There is no difference which wire where goes. Gene. Thank you, Gene
Many thanks for this post!!!! I've been looking for this answer for a few hours all over the internet. I'm glad I found it on this forum!!! Keep up great work!!!
