Can I just cut the faucet adapter off and attach the water feed and the drain lines to existing permanent lines? On a previous Maytag model, I had to replace the water inlet valve with a different valve to make the installation permanent. This model was from 1982 and I had to purchase an installation kit to do this. Was wondering if there was an easier way to accomplish by task. Thanks
The only way to convert a portable dishwasher into a built in is to use a special conversion kit designed by the Maytag. - The part number for the dishwasher conversion kit is AP398418 Happy Holidays! Gene.
