Hot water won't run. When hot is selected on Control Panel, the machine doesn't come on. When warm or cold is selected, the water flows into the tub but it is cold water.
It could be the timer or the temp selection switch, but I think it is the valve assembly.
See if you can use a meter to see if 120v is getting to the hot water valve when the machine calls for hot water. If so, replace the valve assembly.
Before doing anything check that the hot water faucet is ok and that there is nothing blocking the hot water in the valve assembly.
