julimarie
#1 Posted : 17 years ago
julimarie
I noticed things melting in the freezer. The lights were on and the fan was running but I couldn't hear any other motors running. When I tried to pull it out from the wall it took some jerking to get it to move. When it was only a few inches out I hear a fan start running but making a loud clicking noise. I'm guessing it's the compressor fan.
Could this fan motor be the problem it's not cooling? If not, any ideas? Thank you.
misterfixall
#2 Posted : 17 years ago
misterfixall
you are referring to the condensor fan motor.it purpose is to draw heat away from the compressor. the compressor will overheat and shut down otherwise. check to see if th fan blade is hitting the shroud ,or a foreign object is preventing blade from turning .,possibly fan motor is failing .if so replace it .if nothing else is amiss it should return to normal, seasons greetings to you
julimarie
#3 Posted : 17 years ago
julimarie
Thank you! :) It seems the fan blades were bent out somehow and at least one was hitting the shroud. I bent them back and the noise stopped. The fan seems to be running fine. I'm now hoping the frig will cool again.
Thank you again. If it works Christmas will be saved! :D
Now I'm worried. I went to check if I could hear the compressor running but didn't. I listened closely but heard nothing then I heard a click, like it was trying to turn on, then a hum, then a click again and the hum stopped. I've always been able to hear the compressor when it's running so something tells me there's still something wrong.
#4 Posted : 17 years ago
You probably have a bad start relay on the side of the compressor, just pull it out and see if it rattles, if so, order a new one. If overload and relay in one package, make sure you get the original factory part!!
Refrigerator Fans & Compressor not running after reassembly. (Refrigerator & Freezer Repair)
by EC Haney 3 years ago
Monogram ZISB420DRI compressor not running (Refrigerator & Freezer Repair)
by gunns 6 years ago
GE Refrigerator Compressor not running. Help! (Refrigerator & Freezer Repair)
by JohnHoward28 7 years ago
Compressor not running & very hot after moving it to another room (Refrigerator & Freezer Repair)
by scsu96grad 9 years ago
GE Profile Refrigerator PFCS1PJXB SS / Compressor not running (Refrigerator & Freezer Repair)
by nj1971 10 years ago
Compressor Not Running (Refrigerator & Freezer Repair)
by jkon2 10 years ago
wont stay cool/compressor not running? (Refrigerator & Freezer Repair)
by chadf 11 years ago
by repairmon 11 years ago
Power Outage Fridge Fans and Compressor not Running (Refrigerator & Freezer Repair)
by ulric999 11 years ago
GE compressor not running (Refrigerator & Freezer Repair)
by kwolfe 11 years ago
by jeff143143 11 years ago
Fan and Compressor Not running (Refrigerator & Freezer Repair)
by BLACKATTACK 11 years ago
by herman 12 years ago
by Dean F 12 years ago
Refrigerator - Compressor not running (Refrigerator & Freezer Repair)
by GAJOHNSON51 13 years ago
