lingeo
#1 Posted : 16 years ago
lingeo
Over the cooktop microwave - and all "functions" work (fan, light, etc.) except the heating. When started - there is a brief clicking sound from behind the control panel. Interior light comes on - exhaust fan does not - turntable motor does not - but it "sounds" as thought the 'stirrer' motor does (at least something in the 'top' is making a soft noise). I kind of suspect one of the relays in the control panel - - but can't decide if all the "symptoms" fit. Any ideas would certainly be appreciated!!
#2 Posted : 16 years ago
Remove the top grill and open the control panel. Check all door switches. Check how they engaged with the door closed. Follow the tech sheets instructions.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL MH7140XFQ1 | AppliancePartsPros.com
