billyderbes
#1 Posted : Thursday, June 18, 2009 9:13:18 AM(UTC)
billyderbes
Our dishwasher makes a rattling noise, and does not wash properly. The soap doesn't even get fully dissolved. The noise is associated with rotation - it winds down when I power off.
#2 Posted : Thursday, June 18, 2009 1:12:28 PM(UTC)
Remove all filters and screens inside the dishwasher and clean them. Check for a broken glass inside. If it would not help then you have to pull the dishwasher out of the cabinet, remove the circulation pump and check it.
billyderbes
#3 Posted : Thursday, June 18, 2009 8:40:08 PM(UTC)
billyderbes
Thanks. Do you know where I can get a repair manual or procedure so I can get at that pump? If I even knew where it was, I might be able to reach it from the toekick to be sure that's where the noise is coming from.
#4 Posted : Thursday, June 18, 2009 9:09:06 PM(UTC)
The instruction is attached to the reply.
File Attachment(s):
How to remove the base from the tank.doc (550kb) downloaded 129 time(s).
How to remove the circulation pump.doc (635kb) downloaded 146 time(s).
billyderbes
#5 Posted : Saturday, June 27, 2009 9:21:38 PM(UTC)
billyderbes
I got the pump off and found a two piece impeller. Several pegs in the face of one disc engage several holes in the other, but they come apart easily. Is that normal? If so, it seems I should be able to just put them back together. I tried that, but ran into another problem. The pump won't go back in the housing. There are 4 sliding tabs, but no stagger or lead-in. Looks like I have to remove the pump housing to to get all 4 tabs engaged at once. Any instruction on how to do that?
hunterdog
#6 Posted : Wednesday, September 9, 2009 5:13:38 AM(UTC)
hunterdog
Do the instructions you provided for the circulator pump also apply to the Bosch shu9925uc/12?
#7 Posted : Wednesday, September 9, 2009 3:28:14 PM(UTC)
Yes. it should be good for your dishwasher as well.
Here are the breakdown diagrams for the Bosch dishwasher Model SHU9925 UC/12
