norodnik
#1 Posted : Wednesday, June 17, 2009 6:46:53 PM(UTC)
norodnik
I have a problem with the dish washer, it will not heat the water. I have taken the side panels off, and checked the heating element, which reads 11.5 ohms. I believe Gene said that was what it should read. I have a problem with hard water scale, and would like to remove the element and check it for scale build up. The element is sold as a unit with the housing, but it appears to be removable. I ask because I don't want to break the thing, because a new element w/ housing is $187.50. Don't you just love it when they do that. Woody Guthrie said that some men rob you with a 6 gun, and some rob you with a fountain pen. Amen!
#2 Posted : Wednesday, June 17, 2009 10:01:16 PM(UTC)
I would not recommend to remove the heating element just to check it for scale build up. You can run the Dishwasher Magic to clean the dishwasher instead of it.
You need a clamp-on-meter to check the current in the heat circuit to see if it works. If there is no difference in amperage between the heat and no heat cycles and assuming there is nothing wrong with the heater itself (it has normal resistance), the problem most likely is a bad NTC. In this model the NTC is a part of the heater assembly and can not be replaced separately. That means you have to replace the whole heater assembly. I'm not sure if such old machine is worth it.
norodnik
#3 Posted : Thursday, June 18, 2009 2:04:58 AM(UTC)
norodnik
What is the NTC? Thanks for your help!
#4 Posted : Thursday, June 18, 2009 1:44:56 PM(UTC)
The NTC is a temperature sensor. NTC states for "Negative Temperature Coefficient".
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
