Just bought a new house and finding all of the hidden repairs that are needed. The house came with a GE profile quiet power 2 model # GSD4020Z07BB dishwasher. The dishwasher has a small leak and I did some watching during a cycle. When the drain solenoid kicks, water starts leaking quickly off of the bottom of the solenoid. It only lasts a few seconds and reoccurs throughout the cycle. Only about 1/8th of a cup leaks during a cycle. I can not tell that the water is coming from anywhere but the bottom of the solenoid but there certainly should not be any water near the solenoid. Any ideas of what this might be or how to fix it? Please help.
Here are your parts Replacement parts for GE GSD4020Z07BB | AppliancePartsPros.comTake a look in the "Motor-pump" section. Odds are high that it is the flapper valve seal is leaking (Item 417) Might as well get a push on nut also (Item 415), the old one will probably get screwed up getting it off. Check that it is not dripping or running along the frame/tub from higher up, just to be sure. |
THIS FORUM IS DEAD!!!!!!! |
