I purchased a piston & nut assembly from your company, but when I tried to install it I found a small round black sponge disk in the area of the assembly. I don't know where this belongs and it is also ripped in half. It is about 1 1/8 inch in diameter. can you help?
Here is the parts breakdown of a GSD4030 unit Replacement parts for GE GSD4030Y70WW | AppliancePartsPros.comTake a look in the body parts section. If you click on the actual picture of the part a new page will open with better views. Not sure what you have but a couple possibilities are: Item 555 the gasket, though using the 1 inch grid lines, it looks too big to be the part you describe. Item 564 Piston and Nut, I do know that the early ones used a black conical gasket/seal inside, perhaps it has worn leaving you with a ripped outer edge. This would be like you describe, I would think you should be able to see the inner edge has worn badly. Hopefully someone else has other possibilities!! |
THIS FORUM IS DEAD!!!!!!! |
