urika
#1 Posted : Tuesday, December 6, 2011 2:53:58 PM(UTC)
urika
my oven is not heating but the broiler is and the control pad stays on with the clock for a minute then goes off. i have ordered three baking elements and it still doesn't heat ,what do u think could b the problem.
ApplianceJunk
#2 Posted : Wednesday, December 7, 2011 7:58:54 AM(UTC)
ApplianceJunk
If the oven is not heating I would check the simple things first.
First thing I would check is the bake element with my ohm meter for continuity.
I would disconnect the power from the oven and remove the bake element to check it.
