At first machine would not run. Diagnostic indicated low motor current. Took out control board and found a burned and loose connection on board for one of the blue boxes. Resoldered. Now the washer will fill, run, and empty. However, after the first cycle the control board shuts off the power (I guess). Anyway no lights. I can press the drain button at that point and it drains. When I run the diagnostic test now it never completes, but shuts off power as above. Resistances for the motor coils are OK 7 ohms, 7 ohms, and 3 ohms. Wouild the thermistor be bad? Thanks for any help in advance.
I would suspect the control board, especially it was already repaired. If you need the correct part number for the control board then post the serial number of the dishwasher.
Thanks Gene. The serial number is 10307961wq.
Unfortunately this control board has been discontinued by the manufacturer and is no longer available.
