need help, I bought a new computer board to control the water, crushed ice, cube ice. The old one was burned up from the water line cracking and water getting on the board. I replaced the water line and installed the new board. The touch pad is now lit up indicating the crushed ice selection, but no crushed ice gets despensed, also I cannot get the selection to change when I push the button for water nothing happens? The light stays lit on the crushed ice button and will not change to water or cubes? Does this mean the selection key pad is burned up also ? If so would that explain the no ice or water coming out?
