I noticed my Kenmore washing machine making a loud noise on the final spin. When I checked the tub, it seems quite a bit looser than it used to be. Any thoughts?
Rank:: Advanced Member
Need complete model #.If 110 in front, it's a Whirlpool. Pull the agitator off by removing 7/16 bolt and check the drive block nut, probably loose. You will probably have to order the drive block and the special spanner wrench to tighten it.
