sandradandcompany
#1 Posted : Tuesday, June 16, 2009 3:04:51 PM(UTC)
sandradandcompany
Microwave makes loud bussing noise and does not re-heat- I placed some popcorn to try-it read sensor error--I called a repairman--It will be until sometime next week :( Any advice I also did refer to the manual- no luck
#2 Posted : Tuesday, June 16, 2009 5:59:14 PM(UTC)
Most likely the problem is a bad magnetron. The microwave has to be removed from the cabinet to access the part. If you need the part numbers then post the complete model number of the microwave. "XL1800" is not a valid model number.
Cafe fridge keeps warming up. Help! (Refrigerator & Freezer Repair)
by Guest 6/28/2024 8:33:23 PM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
Help! Washer chirping noise (Washer Repair)
by Guest 10/8/2023 6:40:46 AM(UTC)
Troubleshooting Help!! (Dishwasher Repair)
by Guest 6/20/2023 1:14:28 PM(UTC)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 4/18/2023 3:58:41 PM(UTC)
Maytag Dryer MGD7230HW2 LP CONVERSION HELP!! (Dryer Repair)
by prodigey 10/14/2022 3:54:00 AM(UTC)
KitchenAid Artisan unknown problem. Please help! (Blender Repair)
by fakupos 5/17/2022 8:00:10 AM(UTC)
Mah2400aww Maytag Door Boot Door Diaphragm Discontinued, Help! (Washer Repair)
by DIY_Vee 3/4/2022 7:34:13 AM(UTC)
Ice maker dispenser will not stop running - help! (Refrigerator & Freezer Repair)
by Guest 1/30/2022 7:11:17 PM(UTC)
Maytag Bravos MCT HELP!!!!! (Washer Repair)
by Guest 10/23/2021 7:31:14 AM(UTC)
Help! Does motor need to be replaced or cleaned out? (Dishwasher Repair)
by connellh 4/30/2021 8:36:32 AM(UTC)
Kenmore not cooling - Can't get a replacement fridge HELP! :) (Refrigerator & Freezer Repair)
by shorton 11/9/2020 11:33:04 AM(UTC)
Help! GE Profile Electric Oven PT916SMSS (Oven Repair (including Ranges and Cooktops))
by Marsa 5/9/2020 8:36:48 AM(UTC)
HELP! Need clip or nut for Foot on Frigidaire Gas Range (Oven Repair (including Ranges and Cooktops))
by RichardKY 5/5/2020 6:43:52 AM(UTC)
