garybelmer
#1 Posted : Monday, December 5, 2011 2:16:04 PM(UTC)
garybelmer
my washer is coming up with error code f7e1, can you advise on how to proceed?
ApplianceJunk
#2 Posted : Monday, December 5, 2011 3:21:18 PM(UTC)
ApplianceJunk
Remove the bottom access panel on the front of the washer and look for the tech sheet inside. It should tell you more about the error code, not sure what that code is for off hand.
Here is a diagram of your washer and how the bottom access panel comes off.
Top and cabinet parts replacement parts for MAYTAG NFW7300WW00 AUTOMATIC WASHER | AppliancePartsPros.com
Does the error code come up on the display when you first try to start it or what?
garybelmer
#3 Posted : Saturday, December 10, 2011 4:47:08 PM(UTC)
garybelmer
Thanks for replying , error code comes up sometime during wash cycle, sheet was behind door. I am in process of testing motor, and or tach drive.
