awynne
#1 Posted : Tuesday, June 16, 2009 10:37:09 AM(UTC)
awynne
Based on what I have read, I need a new TT motor. Can I use the AP2024962 (GE) motor with a D shaft? Do I pry the coupler off to check or is it a D? I tried pulling the coupler off and met resistance. I realize that I access the motor from underneath but dont want to disassemble until the part arrives. Th Frigidaire speced part appears to be a D shaft but is like 150$. The GE/aftermarket part ref'd above is around $30. Thanks.
#2 Posted : Tuesday, June 16, 2009 6:30:19 PM(UTC)
Yes, looks like you can use this GE motor (AP2024962) instead of the one sold by Frigidaire.
Guest (4)
