the compressor runs but the refridgerator does not cool
What is exact temperature in the freezer and refrigerator?
Does the fan in the freezer run?
Check if there is a frost on the rear panel in the freezer?
Gene, The temperature is the same in the freezer as in the refridgerator. Room temperature. The fan runs in the freezer. There is no frost in the back of the freezer.
If the compressor is running, but there is room temperature in both compartments then the system is low on Freon or the compressor is not pumping Freon. It has to be checked by a certified tech.
