ttb
#1 Posted : Monday, June 15, 2009 7:21:11 PM(UTC)
ttb
While my oven was on, an error code of F7 appeared and the oven light came on along with a beeping. The oven was still heating.
I could hit the cancel button and the time would come back on and the beeping would stop but only for about 1 minute, then the error code f7 appears again the beeping started.
Is it the touch pad or the clock
Dan O.
#2 Posted : Tuesday, June 16, 2009 7:24:00 AM(UTC)
Dan O.
That is suppose to indicate a 'stuck' button in the control panel Keypad. Most times the control panel would need to be replaced to correct the condition.
LINK > WW30430B Control Panel & Keypad Asm.
The oven interior light? If so, make sure the door is fully closing and activating the light switch. You could also check the door light switch operation by manually pressing it with your finger.
LINK > WW30430B Door Light Switch
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
