juki71
#1 Posted : Monday, June 15, 2009 4:30:49 PM(UTC)
juki71
I have a maytag electric dryer displaying eroor code tS when you try to start it. Any ideas?
#2 Posted : Wednesday, June 17, 2009 7:32:37 AM(UTC)
Replacement parts for MAYTAG MDE6700AYW | AppliancePartsPros.com
Here is a service manual, tech sheet and a tech bulletin
http://www.servicematters.com/m...ibrary/docs/16025911.pdf
http://www.servicematters.com/m...ibrary/docs/16026881.pdf
http://www.servicematters.com/m...rary/docs/TDL-0141-B.pdf
I would try resetting the error first, just in case it was just a false error, see the tech bulletin.
Would also clean and check your vent system.
whjirlpool oven won't heat and gets error codes E-1 F-1 (Oven Repair (including Ranges and Cooktops))
by tmlscm 3/6/2012 8:46:01 AM(UTC)
