Having found a compatable replacement igniter unit (according to the web site) terminal 3 on the unit seems to have been changed form an earth terminal to a switch terminal but I only discovered this when it blew on powering up.Anybody out there had the same problem and if so any suggestions on how to get round it? Is there the part with and earth terminal available? Many thanks.
