Im replacing the old 10 hr timer and i lost the wiring diagram im tring to find out in which pin do i place the black wire?
Hi, Here is the tech sheet for your model refrigerator, it includes the wiring diagram. http://appliancejunk.com...wnloads;sa=view;down=375The black wire on your new timer is one of the wires that go to the motor on the defrost timer. You can also figure out were it goes by simply looking at the old defrost timer. If you can't see the motor wires on the outside of the old timer crack it open and you will see how they are connected on the inside.
