Have a kenmore fridge. The Freezer is cold but the fridge portion is warm. I can not find any parts diagrams on this site or on sears site so I can ID parts to check the defrost system. Please help.
So i went home last night...bottom 1/2 of freezer back panel is frosted. I took back panel off. Had to let all the ice and frost dethaw. I can not find anything that looks like a defrost timer (as mentioned in one of the repair forums) As i said above i cant find parts breakdown lists to help me find the parts. It is a top/ bottom kenmore circa 1993. Please help
Ive been repairing all makes and models of refrigerators since 1980 and I still have to hunt to find the timers. Look where the thermostat and air flow knobs are. It may be snuggled in with those controls probably the roof of the refrig section. There is always a small hole to put a flat blade screwdriver in, to advance the system into a defrost cycle.
Do i need to take the floor of the freezer out?
