My washing machine will fill with water fine and agitate fine, but when it comes to the spin cycle, nothing happens......No humming from the motor or anything....I turn the dial manually, and it will begin to fill but when I put the dial in a position that would call for spinning or draining absolutely nothing......TIMER problem?
I think you will find that the LID SWITCH is bad!!!!!!!!:)
