fixitman20111
#1 Posted : Thursday, December 1, 2011 7:40:52 PM(UTC)
fixitman20111
Oven starts fine,preheats and the starts to cook. after a bit it shuts off and displays PF. turn it back on and try again. works for a minute then does the same thing, shuts down and displays PF, so i restart it again. i would like to know what i need to replace. Do i need the expensive control panel or just a fuse.
ApplianceJunk
#2 Posted : Saturday, December 3, 2011 5:47:45 AM(UTC)
ApplianceJunk
Make sure the screws that connect the power cord to the back of the range are tight. Could be loosing power from a bad connection at the block that the range cord is connected to.
