vangoy
#1 Posted : 13 years ago
vangoy
Microwave won't heat. Transformer and fuse have been changed. Which of the three thermostats should be replaced.
ApplianceJunk
#2 Posted : 13 years ago
ApplianceJunk
If the microwave simple runs without heating then none of the thermostats are at fault.
You would have to determine if the high voltage side is getting voltage to start with. If it is not then I would check the door switches first.
microwave won't heat (Microwave Repair)
by Suefink 12 years ago
Microwave won't heat (Microwave Repair)
by gkronenberger 12 years ago
brand new microwave won't heat sensor error (Microwave Repair)
by redcellocase 13 years ago
by lilbart 13 years ago
by frankish 13 years ago
Whirlpool Microwave won't heat (Microwave Repair)
by Wendy Porter 13 years ago
by jlune423 14 years ago
GE Profile Microwave won't heat? (Microwave Repair)
by bill007 14 years ago
by mtorrey 14 years ago
Microwave Won't heat food and turntable doesn't rotate (Microwave Repair)
by PaulieMo 14 years ago
Microwave won't heat/Loud buzzing (Microwave Repair)
by grami 15 years ago
Kitchen Aid Microwave Won't Heat Food (Microwave Repair)
by lmcalpin 15 years ago
Microwave Won't Heat (Microwave Repair)
by cfairban 15 years ago
Microwave won't heat, over the range Mcrw. (Microwave Repair)
by mbradyla 15 years ago
by Joeblas 15 years ago
