Gene D
#1 Posted : Thursday, December 20, 2007 2:46:09 AM(UTC)
Gene D
Ice Maker overfills with water causing thick cubes. Cubes sometimes do not drop due to cube thickness.Water spills over into ice container while filling. Tried changing inlet water valve and this did not solve the issue.
kawfeeman
#2 Posted : Thursday, December 20, 2007 4:41:59 AM(UTC)
kawfeeman
you may be able to remove cover from icemaker and turn down the amount of time the icemaker calls for water ...there is usually a philips screw mounted sideway kind of in the upper right corner and you want to turn in a 1/4 turn to the "-" sign...
Gene D
#3 Posted : Thursday, December 20, 2007 12:47:49 PM(UTC)
Gene D
Jim:
Found what looks like a plastic screw with a slot in the location you mentioned after removing the cover. There is no "-" or "+" so I tried turning it counterclockwise. If anything, it seemed worse so I turned it back to original and then clockwise a good 1/2 turn. I will let you know how I make out.
Gene D
Gene D
#4 Posted : Friday, December 21, 2007 4:34:24 AM(UTC)
Gene D
Jim:
Adjusting this screw did not make a difference either way. Could it be something else besides the ice maker itself or the water fill valve?
Gene D
kawfeeman
#5 Posted : Friday, December 21, 2007 5:07:55 AM(UTC)
kawfeeman
possibly a watervalve situation where it is not seating properly, but somewhat unlikely ... try turning the screw another 1/2 to 3/4 turn clockwise ...
Gene D
#6 Posted : Friday, December 21, 2007 6:32:29 AM(UTC)
Gene D
tried turning clockwise 1 full turn, still spill water over. It does not seem as if it will go in any more (clicks). Should I try counterclockwise again?
kawfeeman
#7 Posted : Friday, December 21, 2007 7:33:00 AM(UTC)
kawfeeman
ok.. is this the screw ( metal ) within the center of a large plastic gear ?
Gene D
#8 Posted : Friday, December 21, 2007 9:47:54 AM(UTC)
Gene D
No its a plastic screw on the outside of the icemaker on the side that you see when you look inside the freezer after removing the cover. Nothing elses is on the outside of the icemaker. I had it out of the freezer. You need to remove 3 screws to get inside where the motor is. Is there anything to adjust in there?
Samsung Ice maker overfilling tray (Refrigerator & Freezer Repair)
by kb5oze 12/26/2011 12:16:02 PM(UTC)
Ice maker overfilling (Refrigerator & Freezer Repair)
by chipmanning 7/8/2011 6:52:51 AM(UTC)
Ice maker overfilling with water (Refrigerator & Freezer Repair)
by jacknbevd 8/3/2009 10:10:47 AM(UTC)
