Rank:: Advanced Member
my customer has a miele dishwasher which flashes,inlet drain ,i can get it to drain +fill perfectly .but will not wash.can hear wash motor .ifeel prblem is circulatingpump wash motor .ilive in brampton ontario .where can i purchse this motor as a dealer. does anyone know the motor instsallation procedure thanks
Unfortunately I do not have any experience with Miele dishwashers and I'm not able to help you.
Maybe somebody else on the Forum can help you better.
thanks anyway Gene, Murrays appliance sevice, out of brampton ontario.
let me know when you are going out there again and i can go over some things to check .. i also have the circ motor in stock but most of the time on that model , it is sensors that offer more problems than anything else..
Sounds like the classic stuck circulation pump impellor. Here is a video on how to get it going again using a modified kitchen fork: https://youtu.be/eXjT1nLDLRo
