Does anyone know of a good place, website or company that sells a complete Appliance Repair ToolKit allready put together with many or most of the common repair tools needed. Like they have Electrician ToolKits or Electronics Toolkits everywhere, but I can't seem to find a appliance repair kit. An example is: It looks like many brands use a 7mm driver socket with a longer reach for instance to change the front door seal. It would be nice to find a ToolKit that someone has already put together. Thanks again in advance.
I don't know of any such toolkit, but it is pretty easy to put your own together. You need a good set of screw drivers, a good socket set including star bits and other speciality drivers, nut drivers, slip joint pliers, an electric test meter and some other thing I probably forgot.
