My Kenmore stove is from .. oh .. 1988 .. the control panel is receeding. It still works .. but is receding. I need to get the front off to see how/if it can be fixed.
... Oh and .. I am hosting Christmas this year .. they begin arriving on the 22nd! Help!:eek:
In order to provide e the most accurate advise I need the complete model number of the range.
Gene, Thank you for the reply. :D :D :D I got that problem licked and now: I ran the cleaning mode and the door would not stop locking and unlocking itself and the fan under the cook top keeps cycling .. oh .. every minute or less.
I disconnected one of the leads to the module on top of the door lock. Now I can bake for Christmas, but the fan keeps cycling.
Does that fan run outside of the cleaning mode?
I was thinking of disconnecting the power to the fan until I can order a replacement for that module.
Is that OK?
The unit is a Kenmore 911.455881.
I hope to be able to nurse it through Christmas then I can replace the module that I think is bad. :confused:
