I just ordered ice door kit from app. need advice on how to remove the freezer door cover panel to install ice door kit. I cannot determine how to remove the trim panel and do not want to break it because it costs $156.00 from app.
The cover snaps on. You may have tabs at the bottom to start at. Remove the dispenser cover by gently prying going round and round a little at a time to prevent from breaking it.
Originally Posted by: woodchuckie ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The cover snaps on. You may have tabs at the bottom to start at. Remove the dispenser cover by gently prying going round and round a little at a time to prevent from breaking it. Thanks for your input. The panel is loose(ie no attachment points on the sides) and is attached only at the top and bottom. Under the bottom is a small 1/2 or 5/8 in slot on the left and right side. I tried pusing a small flat head screwdriver gently into these slots but to no avail. Do you have any other suggestions?
