I had two or three incidents where no lights were on in the frig. I was going to pull it out and check the plug and everything turned on. A little later upon opening the frig, again no lights, pulled the frig out, the lights and motor started working. Third time, I pulled it out but this time no lights came on. I jiggled, probed, vacumed the dust, checked the outlet, plugged into a new outlet, and everything else I could think of. The power cord looks intact and looks new. Not sure where to go from here. Thanks in advance.
check continuity of light switch while switch is in open and closed position ...
