Sunkistd
#1 Posted : Thursday, June 11, 2009 9:13:54 AM(UTC)
Sunkistd
Value was replaced by WR57X10033. A friend took my old part off for me. My issue is the inlet and outlet connections on my old part are both threaded (screw type) and the replacement value has 1 threaded and 1 push in? The new part did not come with instructions and I do not know if it is the inlet or the outlet that still has screw together connetction. Also need to know if there is a negitive and positive side for the power hook up? :confused:
woodchuckie
#2 Posted : Thursday, June 11, 2009 12:05:56 PM(UTC)
woodchuckie
I think the water supply uses the threaded fitting. You can hook that one up and put power to the solenoid and try it before cutting the fitting off of the other one.
Water Value Problem (Refrigerator & Freezer Repair)
by bc4golf 1/6/2009 2:14:33 PM(UTC)
