murph21
#1 Posted : Monday, November 28, 2011 4:50:49 AM(UTC)
murph21
The evap fan motor runs very slowly, continuously starting and stopping. It did run for awhile at normal speed but after a defrost it went back to running slowly. This fan is a 4 wire connection from the main circuit board. Do you think this a fan motor issue or a circuit board issue? Thanks. Frank
#2 Posted : Tuesday, November 29, 2011 2:55:57 AM(UTC)
I would replace both the evaporator fan motor and the motherboard in the back.
murph21
#3 Posted : Tuesday, November 29, 2011 3:25:50 AM(UTC)
murph21
I replaced the fan and it seems to be working. I didn't realize it was a 7.5 volt fan motor. Thanks for your help.
#4 Posted : Tuesday, November 29, 2011 4:53:54 AM(UTC)
You should be ok, you are lucky it didn't blow out the motherboard.
