I need help to remove the drum from my dryer It seems you must unsrew the panel to remove it...the rear bearing seems hooked?... any help would be so appreciated:o
Hi Niki
Sorry no one has replied earlier, the problem is your model number does not come up and this is a pretty old dryer and not a very common brand.
Without seeing it I can tell you that you probably access the drum by removing the top and the front, look for clips that hold one or the other on and then screws will hold the other. You may have an access panel in back to release the tension on the belt.
Good luck, sorry we could not be more responsive.
