bigbadbowtie
#1 Posted : Saturday, November 26, 2011 4:41:13 PM(UTC)
bigbadbowtie
Ok folks. Just finished cleaning/rearranging the garage, winterizing the boat and had a great feeling of accomplishment. I walked in the garage door hoping to grab a glass of tea/prop my feet up and my wife said "Dryer quit working". :) She said it had stopped mid cycle.
Anyway... I think I have it narrowed down but need some expert input.
I checked the door switch, thermal couples, start button, ect. All seem to be working ok. I found the wiring diagram under the console and started checking the timer. I pulled the timer off have it on the bench.
Diagram says when the timer is set to auto/high T-X C-B and C-A should be closed.
I get tone on the meter at T-X but not on C-B or C-A. My assumption is this bad boy is toast.
Before I buy one from here.. just want to double check.
update.. just checked the other settings and all of them say C-B/C-A should show as closed. On all settings those 2 points are opens.
Ray
#2 Posted : Tuesday, November 29, 2011 2:32:00 AM(UTC)
Yes it sounds like the timer is toast.
Roper Dryer Stopped Mid Cycle (Dryer Repair)
by ayoti 11/18/2013 8:18:24 PM(UTC)
Dryer stopped mid cycle, not light on inside (Dryer Repair)
by melissag 11/1/2009 2:31:07 AM(UTC)
dryer stopped mid cycle (Dryer Repair)
by molney 8/6/2009 7:42:52 AM(UTC)
Dryer stopped mid cycle no restart (Dryer Repair)
by busterspal 7/19/2008 10:04:19 AM(UTC)
