Rpray
#1 Posted : Tuesday, June 9, 2009 5:26:43 PM(UTC)
Rpray
I recently replaced the gasket on my both my Freezer and Fridge doors.
Both before the replacement and after - I have noted some water beads forming in the small space between the two doors.
I have examined the seal, it appears to be tight, and both the compartments are keeping all of their items cold or frozen (as appropriate).
Any thoughts?
woodchuckie
#2 Posted : Tuesday, June 9, 2009 7:45:43 PM(UTC)
woodchuckie
Some fridges have a switch you turn on to prevent condensation. It heats that area. Others have the warm refrigerant line running between the compartments to evaporate it. When the cold surface is in contact with the moist room air the water forms. I know this is not a solution but it is my thoughts.
