3 Pages<123
#21 Posted : 14 years ago
Joe,
Did it show any error code on the display?
Try to turn off the circuit breakers for a few minutes. Some times it helps.
jhruska
#22 Posted : 14 years ago
jhruska
Gene,
I reset the circuit breaker & left it off for about 20 minutes. When I got back to the oven, I hear 1 short beep, 1 long beep & then 3 short beeps. The control panel is still showing nothing...no error codes, no lights & still beeps when I hit a button such as the bake.
Any other ideas?
Thanks,
Joe H.
#23 Posted : 14 years ago
Hi Joe,
Sorry for the delay.
Sounds like the new problem is a bad microcomputer.
- The microcomputer Part number: AP3175498
jhruska
#24 Posted : 14 years ago
jhruska
Gene,
Thanks for the info & confirming what I suspected. However I was hoping I was wrong. Well I order, received & installed the part yesterday. Once I turned on the oven on, everything was working as it should be.
I hope this is the last problem I have with the oven. Between the thermostat, the thermal fuse & now the computer board it's cost a small fortune to repair this oven. I hope this is it for a.....long time.
Thanks again for the assistance here!
Joe H.
#25 Posted : 14 years ago
You are welcome Joe and good luck with your oven.
3 Pages<123
