2 Pages12>
Jaroslaw
#1 Posted : Monday, June 8, 2009 8:04:28 PM(UTC)
Jaroslaw
freezer work . refrigerator nothing i need help how fix I open panel inthe freezer was frost evaporator and flap is closed.i defrost.but frezer work ic maker work ,refrig. none help
woodchuckie
#2 Posted : Monday, June 8, 2009 8:10:58 PM(UTC)
woodchuckie
Was there enough frost to block the flow of the air to the fridge or could you still see the coil and fins on the evaporator.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's open.
Jaroslaw
#3 Posted : Monday, June 8, 2009 8:28:07 PM(UTC)
Jaroslaw
the evaporatot was frost and flap is closed.
Jaroslaw
#4 Posted : Monday, June 8, 2009 8:31:23 PM(UTC)
Jaroslaw
none this is cancel
woodchuckie
#5 Posted : Tuesday, June 9, 2009 6:56:49 AM(UTC)
woodchuckie
Diagram 2 shows the parts to your damper and control parts. The damper(flap) should be open to let the cold air in.
Jaroslaw
#6 Posted : Tuesday, June 9, 2009 4:56:13 PM(UTC)
Jaroslaw
i moving damper control nr.4 but not open door damper the control temp. thing not work i open by the manual a put my finger and air is flow , so the control temp is no god #3. how i test this things///help
woodchuckie
#7 Posted : Tuesday, June 9, 2009 8:09:00 PM(UTC)
woodchuckie
Unless some of the linkage is disconnected, I think you got your test results when the damper didn't move when you moved the fridge temp control.
Jaroslaw
#8 Posted : Wednesday, June 10, 2009 5:07:55 PM(UTC)
Jaroslaw
i thing damper is ok
Jaroslaw
#9 Posted : Monday, July 13, 2009 7:16:38 PM(UTC)
Jaroslaw
evaporator is frozen agien after month/help
Jaroslaw
#10 Posted : Monday, July 13, 2009 7:18:05 PM(UTC)
Jaroslaw
evaporator frozen after month /help
2 Pages12>
