alron2
#1 Posted : Monday, June 8, 2009 3:05:25 PM(UTC)
alron2
All the wiring appears to be ok. I have 240 volts at the incoming stove terminal block. I believe it is the K2 relay which is mounted on a PC board? What do you think? Can I purchase just the relays? Help please.
Ron
applianceman
#2 Posted : Monday, June 8, 2009 7:00:30 PM(UTC)
applianceman
If the broil unit will work you are probably right about the relay and you will have to replace the whole control board.
If the broil doesn’t work either you have the other external relay and the thermal cutout that may cause this problem.
Appliance Repair Guide For All Major Home Appliances
Dan O.
#3 Posted : Tuesday, June 9, 2009 1:33:20 PM(UTC)
Dan O.
alron2 wrote:
I believe it is the K2 relay which is mounted on a PC board? Can I purchase just the relays?
I'm afraid the electronic control is only sold as an assembly as applianceman said.
LINK > Frigidaire GLEB30S8CBB Electronic Control
Individual components are not usually repaired in the appliance service industry. If any part of the control is defective the whole thing usually has to be replaced. :cool:
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
