rmcveigh
#1 Posted : Sunday, June 7, 2009 1:32:21 PM(UTC)
rmcveigh
My side-by-side refrigerator is still in good shape but lately the ice dispenser door isn't closing completely and then ice is melting and dripping into the dispenser tray and ultimately creating a mess. I've seen on the site two possible parts to fix this - one is just a new spring, and another is an entire new ice door kit. I'm not clear on what part I need to purchase to fix my problem. Any guidance would be greatly appreciated. Thanks,
-Ryan
woodchuckie
#2 Posted : Sunday, June 7, 2009 4:39:46 PM(UTC)
woodchuckie
Remove the dispenser cover by gently prying going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Inspect the parts to determine what is causing your problem.
rmcveigh
#3 Posted : Sunday, June 7, 2009 5:57:08 PM(UTC)
rmcveigh
Thanks for the advice woodchuckie. I took the cover and the electrical panel off and low and behold, the spring isn't the problem at all. If I remove the "mechanism delay" (what looks like a little piston) then things close with no problem. Is this a necessary part? In other words, do I need the delayed ice door closing? If so, this part is only available in the door kit, so that answered the question of what I need to purchase.
woodchuckie
#4 Posted : Sunday, June 7, 2009 6:50:59 PM(UTC)
woodchuckie
You do need the delayed door closing so the ice won't be trapped in the door when it closes.
rmcveigh
#5 Posted : Sunday, June 7, 2009 8:04:26 PM(UTC)
rmcveigh
That makes perfect sense. Its too bad that part isn't sold by itself, but it won't hurt to replace the assembly as a unit. Thanks again for the help,
-Ryan
