clenne
#1 Posted : Tuesday, November 22, 2011 11:00:41 PM(UTC)
clenne
The control panel of my Quiet Smart 200 has an LED on next to a padlock icon. The controls don't work (with the exception of performing a "field test," which works fine). It seems like there should be a way to reset the electronics, but I can't find it. Can anyone help me?
Thanks!
#2 Posted : Wednesday, November 23, 2011 12:14:54 AM(UTC)
To unlock the dishwasher controls, press and hold the HEATED DRY pad for 3 seconds.
The light above the lock pad will turn off. To lock the dishwasher, press and hold the HEATED DRY pad for 3 seconds. The light above the LOCK pad will turn on.
Try the above.
If that does not work, get the model number.
Model Number Locator
Then go to the GE appliance website and down load the operator's manual. It should have the procedure.
Control Panel Locked Up (Refrigerator & Freezer Repair)
by vsorlie 8/11/2011 1:51:52 PM(UTC)
Control Panel Locked (Washer Repair)
by MOORELEANNA 7/9/2011 11:01:37 AM(UTC)
cONTROL PANEL LOCKED (Washer Repair)
by Radiant 12/12/2009 1:30:27 PM(UTC)
ge washer control panel locked (General Talk)
by michelleaarons 2/4/2009 12:42:55 PM(UTC)
