jstyles
#1 Posted : Monday, December 17, 2007 1:37:07 PM(UTC)
jstyles
how do I replace heating elements in a kenmore 80 series, heavy duty,king size dryer
misterfixall
#2 Posted : Monday, December 17, 2007 6:25:36 PM(UTC)
misterfixall
if there is heat at start ,i would check the venting at back of dryer to out side. could be blocked or kinked.turn dryer on ,go outside ,check for good air flow, if little flow or none then venting is problem. you can remove venting at back of dryer +test drying a load to see if dryer is fine +venting is problem
Dryer Takes To Long To Dry (Dryer Repair)
by Mhenry3 2/7/2013 7:22:12 AM(UTC)
maytag electric dryer takes to long to dry (Dryer Repair)
by champcar50 8/22/2010 3:56:06 PM(UTC)
Maytag Dryer Takes to long to dry (Dryer Repair)
by astratton 10/23/2009 9:39:57 AM(UTC)
My dryer takes to long to dry (Dryer Repair)
by sandraquin 10/6/2009 8:14:16 AM(UTC)
Dryer takes to long to dry (Dryer Repair)
by Julito 12/5/2007 8:16:19 AM(UTC)
