Legend in Your Mind
#1 Posted : Friday, June 5, 2009 3:47:35 PM(UTC)
Legend in Your Mind
Here's the deal..
A while back the overload relay crapped out on this thing and it took me a while to get around to getting a new one. The new overload relay is slightly different in that the prongs are different so I had to cut the wires and run new leads to them and I'm not sure which is which now so i tried it (wire leads) both ways, neither works and the compressor now does nothing. Before i replaced them the fans and compressor kicked on till the relay turned to crap but now the only thing that works is the lights after replacing the relay. I looked at the wiring diagram at the parts house and noticed there is a fuse, but it appears to also lead to the ice maker. Is there a chance that fuse could be the culprit? All I'm getting right now is lights and nothing more..
Thanks.
Legend in Your Mind
#2 Posted : Saturday, June 6, 2009 3:49:26 PM(UTC)
Legend in Your Mind
Do these things always take a day to start running? Could it have been that it was unplugged for a few months? It's running fine now.. whodda thunked it?
Amana Fridge problems (Refrigerator & Freezer Repair)
by gehrhart 7/25/2008 3:05:40 PM(UTC)
