the Dryer Starter Switch Works Sometimes And Not Others. In This Dryer One Sets The Drying Cycle And Then Moves The Starter Switch To The Right And The Dryer Starts And Stays On. In My Dryer, Sometimes It Stays On, Sometimes It Does Not Work At All, Sometimes It Starts And Then Shuts Itself Off After A Few Seconds. The Part # We4x352 Is Discontinued But Perhaps There Is Something I Can Clean Or Whatever To Get This Going Again. My Dryer, When It Works, It Works Great!!! Do I Have To Throw It Out Because The Part Was Discontinued???
Hi Nydia There are a used appliance parts site on the internet that may be able to help you. Here is one Good Quality Used Appliance PartsI should tell you that it is possible, even likely that the start switch is not your problem, but if you can find one at a reasonable price it is certainly worth a try. My own, unsolicited, and therefore suspect opinion, is that when parts are discontinued for a machine it is the world's way of telling you it is time to replace it. In our area you can get a good used dryer for less than $150.00 and the new dryers, basic model (which is all you need) can be had for $300.00 and up. If you are unable to find the switch, or you do find it and that does not solve your problem that is what I would recommend. Good luck, and let us know what you find out. I think everyone who views this site will be interested in hearing how it turns out with the used appliance part sites.
I went to the website for used appliance parts which gave me the phone number 570-622-6441 and a gentleman spoke to me to sort out my problem. It seems like the switch might not be the problem, but overheating due to lint. He recommended that i take it apart and vacuum all around the bottom and the motor and see if that solves my problem. I want to thank you for your answer. Let's hope this works. If it doesn't, it's time for me to get a new dryer. God bless you.:)
That's good advice and I hope it works. Let us know
Well, I cleaned it and the dryer is working. So I guess it worked!!! THANK YOU.
Fantastic, reallyt glad it worked out for you, and thanks for updating us!
