cgirl11@gmail.com
#1 Posted : Sunday, November 20, 2011 3:37:45 PM(UTC)
cgirl11@gmail.com
The in door water line is broken at the bottom of the door how do I get to it to replace? can I take the freezer door apart ?
ScottEge
#2 Posted : Monday, November 21, 2011 10:29:32 AM(UTC)
ScottEge
How much tubing if there coming out of the door to work with?
If ther is enough tubing about 3/4" a 5/16" John Guess water connector may do the trick. Don't try taking the door apart. It wont work because it's full of foam. If there isn't enough tubing you would be looking to replace the entire door.
