Our dishwasher is leaking from the front bottom of the door. Thought it was the seal because when looking at it from the inside it was missing in the center. When I found the part online the image showed that that middle section isn't supposed to be there anyway. Any other suggestions of what it might be? Should I buy the piece anyway to see if it might be that?
