dyrer lites at start but does not relite at cycle, then will not relite from a new start for several minutes, don't think it ever gets as warm as it should, converted to lp 2 years ago
Originally Posted by: stevejoralmon  dyrer lites at start but does not relite at cycle, then will not relite from a new start for several minutes, don't think it ever gets as warm as it should, converted to lp 2 years ago forgot to post brand and model fridigdaire model fdgb23rgs1
Originally Posted by: stevejoralmon  dyrer lites at start but does not relite at cycle, then will not relite from a new start for several minutes, don't think it ever gets as warm as it should, converted to lp 2 years ago found the fix in the repair blog on this site thank you---- gas coils didn't work replaced them for $39.00 and dryer works like new
