ctaylor1127
#1 Posted : Wednesday, June 3, 2009 6:00:43 AM(UTC)
ctaylor1127
I'm having issues with my Kenmore(Whirlpool) electric dryer. I replaced the motor yesterday, as it was bad, and thought that was the only issue, apparently not. The dryer will start, and run, sometimes all the way through the cycle, sometimes it runs for 5 minutes, sometimes it will go 20 minutes. I get heat, and when it does stop, the timer stops. Is this a bad timer, or a bad push to start switch?? I'm not in a postition to replace the dryer, so repair is the only option. Any and all suggestions are most appreciated. My husband is out of town, and the laundry continues to pile up!!
#2 Posted : Wednesday, June 3, 2009 12:03:51 PM(UTC)
Were you able to restart the dryer right after it stopped? Did it make any noise at that time?
ctaylor1127
#3 Posted : Wednesday, June 3, 2009 5:16:38 PM(UTC)
ctaylor1127
Yes, I can start it when ever it stops, I was just down there changing over loads, and it clicks off, like it would if the cycle were over. When it died originally, it wouldn't even turn on, and the drum was almost impossible to turn, so I assumed that the bearings had seized. It started fine after the new motor. It just doesn't want to stay on.....
Chris:confused:
#4 Posted : Thursday, June 4, 2009 6:39:11 PM(UTC)
Chris,
Does it do it on both auto and timed dry or only when you use the auto dry?
ctaylor1127
#5 Posted : Friday, June 5, 2009 4:36:07 AM(UTC)
ctaylor1127
I'm plain and simple, and I only use the time dry, I don't use the auto dry....
Guest (4)
Kenmore Dryer Issues (Dryer Repair)
by dccmgb 7/12/2008 7:46:39 AM(UTC)
